Sounds like the burrito warmer is finally hitting the market :secret:
Isn't yours still at the Post Office? :D
They sent it back :( I waited too long...
Sent it to the wrong one & they couldn't deliver right?
That's right...
burrito warmer?
That's their next big release...I've been working with them hand-in-hand on getting this out to the market. I'm trying to get away from food at the track, and figured that a frozen burrito has the perfect balance of nutrients to keep you moving down the track at warp speed. Naturally, if you have a frozen food item, you need a way to warm it up. Hence the frozen burrito warmer (integrated into the new MPVI unit).
Now, we've had some issues, especially when the burrito gets a little too warm, too fast. It tends to spill its guts. Be I think we have this worked out. You should be very impressed.
I was thinking about PM'ing you to tell you the burrito warmer was coming your way soon.....but you beat me to it with this post..LOLQuote:
Originally Posted by MeentSS02
I foresee grounding offset problems with the Burrito Option.
Can we have black box logging instead of a Burrito warmer please?
id like a feature to charge my flux capcitor 3x faster.:)
Will this support only bean burritos or also beef burritos? :) My car can run with both, so I may as well utilize this option. So I really need to have the MPVI ... it will not work on serial cables? :( Also, if like PurplePiss says, can we create a custom PID for the offset? :eek:
Burrito type is not a problem at all...it'll take bean, bean and cheese, beef, enchilladas, you name it. Voltage offsets are really not an issue either...they are typically +.2-.24 volts off (depending on type), so if you just set it at +.22, you are covered.
Next question please.
Oh thank god! :D Has this been tested on 4x4 truck applications yet? I am willing to be a guinea pig, but fear it may get unstable (messy). :o
What about something smaller? Say a soft taco? Will this option be covered as well? I don't wanna lay out cash, if my tacos are gonna be burned and crunchy...
Soft tacos can NOT be used...as for 4x4 testing, you can be the first.
What is the approximate time it will take to heat say a beef burrito from about 37*F to around 120*F? I would imagine the more HP your car makes the more wattage the heater will see so lets assume an average of 400 hp. If its around 30 seconds I may look into one. :D
It is closer to like 2 minutes, maybe more. HP really doesn't have much affect. BUT I'm working on a two-step as well, so the heater is already bouncing off a preset limiter before popping one in. This might not be the best option for you right now...
OK thanks for the recommendation
Wouldn't it require separate licenses for burritos vs. tacos? If you get the tuner shop version, I assume it works on any frozen food.
How many credits is this going to cost to get the unlimited warming? Chris!
