Coyote Crank Relearn "How to Video"
Hey guys,
I remember someone asking how the crank relearn process works. Well I recently had the clutch swapped on my mustang and decided to make a video of the process for reference. It is as simple as the process sounds and takes less than a minute to complete.
You won't know you need to do the process until you actually try to rev past 4k rpm, the check engine light will flash and it will misfire a ton. When the car was started it drove fine with no CEL until after the first attempt to rev past 4k.
https://www.youtube.com/watch?v=MHsG...ature=youtu.be
