Permanent DTCs and VCM Scanner
What is a Permanent DTC?
Starting in 2009/2010 MY, vehicles now store emission related DTCs as Permanent DTCs. Unlike non-Permanent DTCs, Permanent DTCs can not be cleared by any conventional method like a battery disconnect or via any scan tool. Permanent DTCs will only clear automatically after the module storing the DTC, sees that the problem causing the code has been solved.
Please Note: It may take a few drive cycles for the DTC to clear if the issue causing the DTC is fixed. If the issue causing the DTC is never fixed, the Permanent DTC will never clear.
What does this mean for VCM Scanner?
With the release of VCM Suite 3.0 earlier this year, we have strived to make VCM Scanner the most comprehensive scan tool available and to report as much information as possible to you. This includes reporting Permanent DTCs. All versions of VCM Suite 3.0 or newer will report Permanent DTCs, but like stated above, they can not be cleared by any scan tool, including VCM Scanner. If you see Permanent DTCs being reported in VCM Scanner, it is not a bug, the module storing the DTC just hasn't cleared it yet.
need stock lt4 tune 2018 camaro
I have a 2018 Camaro ss with lt1. I swapped the engine with a lt4 I'm looking for a stock lt4 tune. Anyone that can help with that would be greatly appreciated.
