Questions regarding the MAF and tuning
1. My MAF (and T/B) is about 2.5% bigger than stock.
a) What do I have to adjust in my tune to optimize things?
b) Should I raise my airflow in "MAF Calibration: Airflow vs. Frequency" by 2.5% all across the table?
2. I want to do a LTFT tune and I have to disable the MAF first.
a) If I tune it with the MAF disabled and get everything spot on, then what happens to my tune AFTER I enable the MAF again? Do values get messed up or does it (make no difference) just make it easier on the PCM (like a 2nd data input) by using both MAF and VE readings?
b) I can just disconnect my MAF plug instead of messing with my MAF settings/tune, correct? My IAT sensor isn't part of my MAF.
3. Where is "MAF File High" and/or "MAF Sensor Fail Frequency" in the Editor anyways (as mentioned in 2 tuning instructions)? All I have is "Airflow vs. Frequency" under "MAF Calibration". Is it the same thing and what-was listed in previous Editor versions?
