AEM 4110 with version 3.4 using serial - MPVI standard
Hi guys,
I have my AEM hooked up through the EGR using version 2.24. AEM white analog wire to EGR pin on pcm, everything worked and I could log AFR.
When I upgraded to version 3.4 it no longer logs. So I got a serial cable and wired the AEM blue serial output to Pin#2 of serial plug, and I grounded Pin#5 of serial plug. I then use a serial to usb adapter to the laptop (using windows 10). My laptop recognised the adapter and said it was operating correctly.
When I add the channel in scanner and select the AEM, I then see it in the channel list. If I start log it just disappears. I tried the AEM EQ ratio and AFR, same problem. I then also "transform", and selected the parameter insert, and selected AEM 4110. When I start log, same result where it disappears.
Any help would be appreciated.
Thanks.
