1 Attachment(s)
6r80 circle D converter problems
The car is a 2015 v6 with a procharger it has around 440whp, the problem is when i take it to the track and try to heat up the tires the car feels as if brought it up to 4000 rpms and dumped the clutch, after that it will not go into reverse, and while on reverse like that the car cant be pushed back, it has to be put on D and run a couple of gears before it Reverse works again.
On the 6l80 i only needed to adjust the tcc pressure settings or it would slip, on this one im lost.
so can you guys look over my tune and see if there is something wrong with what i have done?
Attachment 75700
