3 Attachment(s)
Challenger Scatapack, Throttle delay
Want to pick you guys brain on this one, car is 2015 Dodge Challenger Scatpack, M6, pretty much stockish
I'm having a throttle delay issue when i'm accelerating from idle at low speed, say i'm doing 6-10mph, close throttle so i'm not on the gas, the car is moving on it's own, and i give it gas quickly because i want to accelerate to gain more speed, but it takes what it seems a full second for the car to actually engage the throttle and move out...
See print screen below, i'm giving her gas right where i have the marker, look at the expected torque 324ft/lbs, actual is only 23ft/lbs, but the car has to literally think for about half second or more, before power starts flowing and the car picks up speed, which is when the actual TPS goes up, MAP goes up, etc etc, in the graph, this doesn't seem to happen if i'm actually on the throttle, for instance if i'm pressing the thottle slighty to keep the speed at 10mph, and i stab it, then things work as expected, TPS goes up and the car moves out, but on close thottle to open, there seems to be a huge delay between the time i give it gas, and the car gains speed, typically not an issue for the most part, but like yesterday i was on 3rd gear, a fool cuts me over, so i have to slightly tap on the brakes and move left, i'm doing about 25-30mph or so, and went to give her, got nothing for about a sec.
I'm attching 2 longs and my current tune
https://farm5.staticflickr.com/4596/...9104c14d_o.pngthrottle_delay1 by Wrangler RSM, on Flickr
