Smoothing out the tables?
So, I'm looking through here and reading many threads on tuning and there are many mentions of smoothing the tables, when it relates to timing, throttle pedal/pedal map, and fueling. Are you folks just looking at three cells at a time and picking the middle one to be between both side values?
Looking at one of the two Pedal Maps (Transient, Steady State) I see that the value (2007 5.9 ECM) for 25% accelerator pedal goes from 33.2 (600rpm) to 30 (650rpm), 28.3 (750rpm), 23.2 (800rpm), 23.2, 23.2 (1000rpm), jumps to 30 at 1200rpm, then 30 and finally 35 (1500-3000rpm). So are you folks making, say, the 650-900rpm values 30.0, and 1000rpm and up at 35.0? Is that considered smoothing? Is there a reason why the pedal drops to 23.2 in the idling range? Is this to allow for more finesse of the throttle, and more travel/movement to better control takeoff?
For the timing tables (Main SOI/Transient for example) or fueling (Main Inj Pulsewidth), do you use the Smooth Selection or Smooth Between Horizontal or Vertical Bounds buttons to start? The timing changes in various parts of the table so I wouldn't want to smooth the entire table at once, but from where to where to folks usually go? I'm sure the smoothing buttons are there for a reason, but should they be used?
Thanks for the feedback.
