P0332 Knock sensor low voltage 04' lq4
I replaced both knock sensors, and their pigtail.. I think I have a wiring fault.. Until I trace it, does anyine know for certain if the PCM will engage KR at WOT simply because of this fault?? It is presently doing KR @ 10 degrees in WOT. I hear no ping, engine runs fine, 12.25 AFR command in PE mode @ 50% throttle.... Nothing else done- PE brought it to life, despite the big KR.... I know- I need to fix the wiring, but I just wonder if that P0332 will engage PCM KR on it's own, or not??
