1 Attachment(s)
Lost TCC lock up when MAF enabled
So I have been battling with a trans issue now since my trans has been corrected. I had a line pressure issue, and got that worked out. When I go to tune my MAF, I loose tcc lockup. If I keep the truck in SD mode it works like a champ. I take the exact same tune, change the MAF fail from 0 to 13,500 and load it and I instantly loose tcc lock up. I am at 100% lost as to why. I can go in the scanner, and force it, and it will lock up when the MAF is on, but it will no longer do it on its own. I did not have this issue before. I am wondering if I just need to move a few #'s around in the tune, as I have seen weird/odd little things happen in the past. ANY help is appreciated!
Here is the tune.
