2 Attachment(s)
Wideband on scanner acting weird
I just reinstalled the wideband from my firebird back to my 98 z28 Camaro, and the install went smooth and all seemed fine. The gauge reads around where it was when removed from the Camaro originally, but now the problem is, in the scanner the wideband reads mid to high 9's. The gauge is reading around 13-14 like it was before, but the scanner is reading way off. The only time the scanner really moves is when the car goes into decel, or when engine is off and the afr goes all the way lean on the gauge. Any other time the scanner only reads in the high 9 range. I made some changes to the scanner, but not sure what all it changed since I just reverted to an older layout I had made, but changing back to what I had doesn't seem to do anything. I checked all my connections in the car and everything is tight and orderly. I run my wideband through my egr, and haven't had a problem like this before. Any help is greatly appreciated.
Attachment 81620
Attachment 81621
