Looking for a plug and play solution for a 2016 boosted Colorado. Tried the GM- regal/6.2SC Vette MAP but it does not seem to work according to my tuner. Is there a way to make it work or is there another sensor I can use?
Doesnt work as in how? Wont plug in? Doesnt read correct?
The 2015 supercharged Camaro ZL1 6.2L uses the same MAP sensor as my 2015 Colorado 3.6L, so there should not be any negative issues from using the stock MAP sensor since both vehicles use the E92 engine controller. At least that is my experience.
https://www.rdpstore.com/p-2326-gm-3...vette-zr1.aspx
correct MAP and Offset numbers .. with the Colorado and LFX your gonna want to tune it for Maf only thats how us Boosted guys run it
