At what point is it a must to port the IAC opening area on a TB?
I have a 408 with a NW 102mm dbc throttle body and I'm feeling porting the IAC would be the only fix without replacing the throttle body. Warm idle iac counts are at 0 and on a cold startup at 310 and its barely enough air to start it in 90 degree weather. If I tun the ide set screw slightly to close the blade (enough to drop tps voltage by .02v) then it jacks the counts from 0 at warm idle to around 150. I've been pulling my hair out on this one, just wanted a second opinion.
