Programming 2012 for newer turbo
Does anyone know what parameters need to be changed when replacing the turbo on a 2012 with one from a 2015-2017 turbo. The shop where we'll be taking the truck has the swap parts in stock but said the reason it's not more common is the tuning. Supposedly the newer turbos don't have a wastegate and will through a code if unplugged. Could I just turn off the code or will there also be a derate? It's a cab and chassis and all the years are rated at 300hp, so could I also copy the turbo control maps from the newer trucks?
Edit: I did some more checking and it looks like they work without tuning. I imagine the wastegate controller stays plugged in but the hose will just be disconnected.
