Originally Posted by
Ben Charles
Desired map is important to view vs actual... what happens when you add a cam.. map KPA goes up so desired vs actual changes quite a bit depending on cam size.. this plays into the Tq model and needs to be changed to reflect the cam, I do this on the Tq map coefficients..
I also work my spark on my Tq model from 0-40 degrees spark and cylinder load and map little past what I will see on the setup..
The Tq coif is setup in Standard form at 800mg which is .80 cylinder load
NA cam stuff I change this to around 1200 which is 1.20 cylinder load
