Before I install a another new set of plugs and change the oil in this 2002 GT 4.6 I figured I'd post this question. I'm having an issue with a set of FRPP 47 lb injectors. I have read several the threads pertaining to injector data in these EEC-V pcms and I am at a loss.
The car was brought to me with the injectors already installed and the installer had ran the car a few times without any tuning. The installer had also installed a procharger. After I changed the plugs, oil, and reinstalled the factory injectors (to verify the engine started up and idled and accerlated without boost ok). I then reinstalled the FRPP 47 lb injectors. Next, I entered the data from https://performanceparts.ford.com/pa...-9593-lu47.pdf and attempted to start the car. The engine is extremely flooded and will not start. Raw fuel smell comes from the exhaust and my wideband is pegged at max rich while cranking.
I have attached the tune it came in with and the FRPP data entered. Would someone mind taking a look and seeing if I'm overlooking something before I tell the customer to get me a different set of injectors?
Attachment 88376
:worship::worship::worship:
