High pressure desired Pump settings
has anyone had good results in tuning fuel system via HP tuners? tried raising High pressure desired to a higher number in the upper cylinder mass. the desired never change, the desired pressure remained at 2900 pis even after I up it to 4000 which surprised me. I realise by raising the desired may not do anything to real fuel pressure, but I never messed with the stock settings. did anyone have good results in tuning fuel pressure? my current setup has a low side fuel pump, just trying to see if commanding higher fuel pressure from the mechanical pump would get me more fuel.
