3 Attachment(s)
2019 Charger Scat Pack Cammed cannot get it to idle on ANN, but runs great on VE
Hello,
This will be my first Dodge that I am tuning (usually do Fords). Thank you for taking the time to read this post.
stock injectors
Long Tube Headers
MDS Delete
Phaser Limiter 7 degrees
MMX NSR Stage 3 Camshaft NA 201-000-17
Intake Exhaust
Lift .595 .557
Duration: 268 285
ICL: 109
LSA: 112.5
@.050 Duration: 220 232
I am having the hardest time with ANN tuning with this particular setup. When I go to start it and log, it will fire up, then die right away.
To get it off my lift, I disabled neural network to get it running and idling and to get it on the dyno. I tuned the vehicle on speed density and made 435HP/426TRQ, but also noticed VVT was not moving.
From my understanding, I needed to dial in ANN to use VVT. Turned Nerual Network back on and again, start up and dies immediately. I noticed on my dyno wideband it was dumping a lot of fuel (11.3) so I proceeded to pull fuel out and try to get it idle and I've had no luck on getting it to stay running. I cannot even take a long enough log to read fuel trims. I feel I'm missing something significant that will correct this issue. I have attached 3 maps. one when I dialed it in on speed density and the ANN map I was trying to make from the stock map I have, along with the stock file.
Attachment 89562
Attachment 89560
Attachment 89561
