3 Attachment(s)
New To Tuning - Running Very Rich
Hi, I am new to tuning and I need help with my very rich tune.
I just built a 5.3 LM7 with a mild cam. I started with disabling VATS and tried running it with just that. It would start and die. If I held the throttle open just a little, it would run for a few seconds before dying. It is very rich to the point that my eyes are burning and the plugs are wet. I made some changed to the tune for the cam like raising the idle RPM to 750 and raising the base running air flow among a few other things according to what I found here. It now will start and run if I hold the throttle open a little. I can rev it up without an issue and, as long as I don't completely close the throttle plate, it will remain running. But it is still very rich. What I need to know is where to start attacking this.
I made an original write-up with what I have and was doing. https://forum.hptuners.com/showthrea...w-to-HP-Tuners
I have the tune with VATS disabled, the injectors changed, and the 4L80e segment swap. I also have the current tune with what I changed for the cam.
