Does data from a 1000cc injector apply to another 1000cc injector,example 1000cc fid to 1000cc id would data have to be changed seeing both are 1000cc.
Iv used ID1000 Data on Fic 1000 injectors with success.
If you email fuel injector clinic, they will send you good data for your set up. Tim is the one responsible for the data. His service and response time was amazing.
Id1000 data would not work with the fic1000 injectors that were installed on the vehicle.
I have fuel injector development 1000cc some off the big names like Lund vmp dont deal with these and I'd like to try there tunes
no you cannot run another injectors data for a different injector it will be incorrect.
At best you can use it for startup but you will still need to dial in the injector data for your specific injectors.
