1 Attachment(s)
2015 Mustang GT Tuning Twin Turbo (Speed Density?)
Hey all just wondering if anyone can look at my tune file and give me some advice. Right now the issue I'm having is I cant get the car under 13.5 AFR during boost. I have double and tripled checked everything and can not figure out why this may be I'm hoping someone here can see something simple I forgot to change and fix this. I have not done any full throttle pulls because I don't feel safe running my boosted car at this AFR, it sometimes goes leaner than that.
Also, on a side note two other issues I'm having is when I update the numbers on the Speed Density Calculator it always ask me to Calculate Coefficients. Once done the numbers almost always revert BACK to what they were and sometimes a full column of 0's will appear. Can anyone enlighten me what I am doing wrong here? The other issue is when I disable Mapped Points 1-14 the car will start but not run or idle, I have NO throttle. I thought it had to do with my Distance Tables but even after changing the values it all leads to the same result. Can anyone also help me with these issues?
The setup is precision 6266 turbos on 8psi, DW 78lbs injectors, MAF inside 4 inch IC pipe and DW Fuel pump, Thanks!
Attachment 93028
