2 Attachment(s)
Time to learn new Alcohol %
I just installed a FF kit on my '18 Camaro SS 1LE and enable what was needed in the tune to get it working. I have verified that the sensor is working both in VCM Scanner and with my Aeroforce Interceptor gauge. I've been using a tune posted on Camaro6 as a starter guide to get everything enabled. I haven't yet filled up with e85. How long (sitting at a gas pump, at warm idle, for example) does it take for the car to learn its new ethanol content percentage? Can the process be sped up by changing the Learning Trigger - Delay Volume and Transition - Transition Volume values in Engine - Fuel - Flex Fuel any?
Attached are the current tune on the car so far (Mongoose FF v1.0 - which is the sensor and diags enabled, Stoich table changed, IAT Mult4 changed, cranking spark alc adder, and CAGS defeated) and the tune I am using as my guide (2016_ss_...). If anyone could check over what I've done so far to make sure that I haven't missed anything important and that I am on the right track and safe, that would be awesome. Car has a Soler ported TB, ported stock IM, and the secondary cats deleted. Stock otherwise. Thank you!
