4 Attachment(s)
392 Challenger SRV issue
2015 Challenger 392 A8. 218/226 114 cam. I'm having an issue with the SRV valve shutting at 5700 rpm then re-opening at 6100 during a dyno pull. Just wondering if anyone else has seen this? I have played with the rpm enabled and disabled tabs and can only get it to just not open. Pic is with it enabled with it shuttling on the red pull. Blue pull is with it disabled.
Attachment 97233
Attachment 97234 Attachment 97235 Attachment 97236
I wonder if those P2008 and P2016 codes have anything to do with it?
Those are old codes from a couple runs I did with the srv unplugged.
Make another run and log short runner valve pwm.
4 Attachment(s)
I'm not seeing and pids related to the srv in the scanner. I was able to log it with a snap on scanner. It's definatly on, then off, then on again. Maybe some missing tables?
Attachment 97243
Attachment 97244
Attachment 97246
Attachment 97245
What is your aircharge when this happens, as in just before, and just after? Yes, there is a couple tables missing that control SRV, so you may not be able to fix this.
I logged it in the first post. It changes very slightly. A few hundredths. Kinda figured we were missing tables.
