1 Attachment(s)
cam issues
So I've been tuning Gm vehicles for about 10 years now and I've been doing Chrysler vehicles now for a year.
The issue I am having is after installing a xfi 273 and a hrt2 cam in two customer vehicles I'm getting complaints that neither cam lopes like they are supposed to, and I cant figure out why because after watching videos of others cars with the same cam they all lope. All the cars I have done have a perfect idle.
I have tried changing the proportional p/n table and it hasn't helped. To be honest no matter what I do it seems the only thing I can make it do is idle hunt.
some help would be appreciated.
1 Attachment(s)
here is a log, though I'm going to go in and lower the minimum spark table to see if I'm fighting with the car
I think lowering base idle has helped slightly, now I need to drive and make sure it doesn?t die when I come to a stop.
Ok can I change my issue into the car idle drops to almost dying then bounces back up. The only cure is to reside minimal idle, but by doing that it gets rid of the lope.
lean out the idle a lot and bring the fuel back in to give it the characteristics you want. also lowering timing in these areas will help, after that your can change the proportional tables.
Hey man thanks for the reply. I?m currently working on VE tuning right now and I?ll have to try out your suggestion. It?s double edged sword because everyone wants the lope while I?m also trying to make sure I don?t have low rpm bucking.
IF YOU CHANGE THE P/N TABLE BUT YOUR MINIMUN BASE TABLE IS LOCK AT 20* THEY WILL NOT FLUKE THE TIMING POSITIVE AND NEGATIVE NUMBERS BEACAUSE YOU ARE LOCK AT 20*. PUT THE SAME NUMBER ON IDLE 512 RPM TO 928 RPM ON THE PART THROTTLE TABLE AND THE MINIMUN BASE SPARK
TRY -10* OR 0* AT YOUR IDLE AREA IN THE PART THROTTLE TABLE ON THE 512 RPM TO 928 RPM
THEN THE PROPORTIONAL P/N MULTIPLY BY 0.5 2 OR 3 TIMES AND MAKE TEST. MORE MULTIPLY MORE TIMING FLUKE (MORE LOPY SOUND)
THE LOG IT SUPOSE TO FLUKE POSITIVE AND NEGATIVE DEGREES IN SPARK AT IDLE
[email protected] I hope it help let me know
If you need someone to tune mopar for you shoot me a message. Demigodtuning on facebook.
You need to clean up the ve.. turn off the vct to make adjustments.
Why is the pe table zero'd out, is it because you tuned the ve... that seems very dangerous
Pe is turned off because I was in the middle of tuning VE it gets turned back on afterwards
Thank you for the reply, though it was fixed awhile ago already it was a very simple process in the end.
The VE is perfect right now, car stays between -1 and -3
Excellent. Glad you got it going bud
