Etc/tps wires chewed up in sc pulleys now car is LEAN
So had a few zip ties break which let the etc/tps cables get pulled into my vortech pullies, so I cut each end off as the wires were stuck between two idlers and matched the wires up and soldered some new wire from the break to the plug which thankfully didn?t get eaten. So after fixing that I started the car up and ran the scanner which the car was sputtering pretty good but I attributed that to my emissions reduction mp10 to being off which hasn?t been an issue besides sounded meh at startup when it?s warm. Now my real problem is the stfts are right around 50% lean and I tried reloading the tune with write entire to no avail which had been working great (big shout out to wht5.0). Any of you pcm and inner workings gods have any theories as to what I?m facing here? In quite a bind!
Thanks in advance!
