As the title says. Looking for someone who has a tune that is working well for them. I have 30lb injectors and bbk throttle body. Otherwise stock motor.
Also trying to figure out how to command open and closed loop operation as well
I figured out how to disable closed loop and it runs really good now without the computer trying to change af
are you running a wideband?
If the PCM was affecting fuel trims that much then you need to dial in the fueling. If you think it "runs really good now" with it in open loop just dumping its heart away then you'd be floored with a proper tune in it....
you should post a log , maybe we can help you
