Have a 2018 a10 mustang I put comp cams (stage 2) in
Upon startup car ran good, but then made a small ticking noise, and threw a check engine light (p0340, p0344)
Decided to pull it apart and double check cam
Timing was set correct, I didn?t see anything wrong however I retimed it, and same thing happened. Ran good a bit (2-3 min) Then made the noise, stumbled, and threw the check engine light
When it throws the code the engine smooths out, however all cam timing is reverted to 0*
Is the anything that needs to be changed in the tune on these gen 3s for cams?
