3 Attachment(s)
Flex fuel and fuel tank inconsistent readings
Car is a 2004 GTO with a P59 PCM, 12587604 OS upgraded to 2 BAR OS with flex fuel enabled. You can see in the log and below that the Alcohol % is all over the place:
- 00:00 time 25.0%
- 00:41 time 35.9%
- 02:17 time 06.6%
- 03:14 time 24.6%
- 04:15 time 00.0%
- 10:25 time 25.0%
Obviously this is messing up trying to scan AFR error as the EQ ratio is all over the place even though the fuel in the tank is the same blend.
Also my Fuel tank level is reporting values all over the place:
- 00:00 time 0.0 gal
- 03:56 time 1.0 gal
- 06:52 time 4.0 gal
- 10:43 time 4.7 gal
- 11:52 time 1.6 gal
The fuel level gauge in the dash shows empty with a very low fuel level when I first start the car. After about a minute or so I get a "fuel gauge error contact dealer" message. Sometimes the gauge will start working normally for a brief period of time before going into error mode again. Unfortunately the gauge does not seem to follow the fuel tank level PID in the scanner.
I'm attaching my tune, log and layout. Any ideas where to start looking?
Thanks!
