Driver Demand Torque? Why some tunes aren't changed...
I've been doing a lot of comparing stock vs the FRPP 2 and FRPP3 tunes, along with a few other ones I've seen people post. I think I've confused myself a bit. Between stock and FRPP2, there are definitely changes in the driver demand TQ settings, but only in the low half of the RPM range, and only in the mid accelerator position settings. It's my understanding that FRPP2 and FRPP3 both have different, but higher power numbers according to Ford's own graphs, however stock/FRPP2/FRPP3 all have exactly the same numbers in most of the chart, including the highest (90% pedal).
I would have thought that one would need to or want to set it at how much torque the engine is actually capable of.
In some other tunes, I found a whipple tune for example, the driver demand table was clearly changed and the numbers "make sense" in that they more or less mirror the gentle 3D slope of the factory tune, but obviously with way higher numbers. I've found other tunes however, where the entire top few rows (Let's call it the last 4 rows) have exactly the same TQ number (top to bottom) e.g. 49.7% = 315 (No matter the RPM) and 57.2% = 350 (No matter the RPM). In these tunes, the torque peak is higher than stock, but I don't think the tunes were for a completely stock car.
I know that the engine can only make the torque it can make, regardless of what the driver demands. So theoretically, could one set the entire table to 900 for example? I guess what I'm getting at is setting it too low would leave torque on the table (bad) but setting it too high wouldn't actually get more power than possible, but also wouldn't leave any on the table? I'm guessing this is for pedal feel more than anything else, but perhaps I have got that confused with the driver demand > pedal characteristics?
Sorry for all the questions - I do try to figure them out using both the "Coyote Cookbook" and the "Master EFI Tuner" books before bothering all of you.
Thank you
