How does it work? You can adjust it quite high. Does it act like an actual trans brake or does it just pull negative timing so it doesn?t make any power? Just curious.
It's just a rev limter basically. The torque converter stall speed will be your upper limit.
Ok. You can set it as high as 3000. Seems like a pretty spicy stall for stock vehicle.
Go ahead and try 3000rpm and let me know how it works for you.
I know. I’m just wondering how it works.
