More data streams for the 6L80 and/or 6L90
Quote:
Originally Posted by
Snap
I have recently been reading and learning about the messages on the high speed (HS) gmlan canbus. My goal is to understand which of the messages are and make them available for everyone :)
Searching the internet, there are some messages covered and the 'GMLAN bible' doesn't help a lot when it comes to the HS messages. My understanding is that GMW8762 covers the message ID's and format.
Does anyone have access to GMW8762? It would help a lot. To start I really want to hunt down the elusive "AC compressor command" so I can manually send it without the BCM.
Otherwise, does anyone have any captured data from their vehicle they are willing to share or exchange so I can pick it apart for the communities benefit?
This is an example of the datastream:
ID DATA
F9 00004000000000FF
3C9 0400000000000000
1ED 0190000000000E54
C7 03FE0000
280 0000000000000000
1AF 0000
191 06150615056F0000
C7 03FE0000
1F9 000000008000FF00
19D 00000000000000FF
C7 03FE0000
12A 42000000B2661FFF
134 00001000
1EF 00000000
F9 00004000000000FF
3C9 0000000000000000
F1 8D000040
C7 03FE0000
F1 B1000040
19D 40003FFF000000FF
1F5 0F0F000100000300
C7 03FE0000
199 8FFF0E70F18E00FF
F1 99000040
1E1 00FE060040
C7 03FE0000
C9 0000000700400800
1EF 00000000
F1 A5000040
example. message id's with ID 1F5 have the PRNDL shifter status (great to know if you 6l80 tcm sends reverse status over gmlan)
byte 4 is the status
1F5 0F0F000100000300 - this is Park
1F5 0F0F000200000300 - this is Reverse
1F5 0F0F000300000300 - this is Neutral
1F5 0F0F000400000300 - this is Drive
I have heaps more info to share if anyone is interested.
Hello Snap,
I would like to take you up on your offer for additional Data Stream examples
If you were able to supply data streams for each gear
Park
Reverse
Neutral
1st
2nd
3rd
4th
5th
6th
If you are able to help that would be much appreciated
Many thanks,
Brent
