2 Attachment(s)
boosted camed 6.1 forgets idle
hello,
i have a problem that is driving me insane , this car is a 2008 6.1 with a cam , procharger , id1050x , fore triple pump
now i tuned it perfectly to a T , it drives great idles great goes from P to D without any problem . The issue that it would drive normal for a week or two then suddenly starts surging when changing gears from P to D or R like the rpm drops and rises . it has happened three times so far , all i do is REFLASH THE SAME FILE without any changes
and it works normally again for a week or so
i reset the adaptives to see if something is causing this but that did not fix it
i changed the pcm to a new pcm and the same thing happens
i have brometric learn turned off and sensed map enabled
has anyone been faced with this issue and what can i do to fix it
what would cause this ? what changes in the weeks span in the ecu to cause this ? is there something else besides adaptives that do
i attached a two logs one with the surge at the end you can see the rpm drop and the other is after flashing the same tune again and you can see it shifts perfect Attachment 105509Attachment 105510
