can someone look at my log file the car is dumping fuel at idle and the inside of the car smells like exhaust
Are the STFT reading on your scanner, they didn't seem to want to show on that log, Not much was logged from what I can see. Do you have any normal tunes from them, without Ghost cam idle? , Or stick the stock file back in it for diag.
only things done is cat delete and resonator delete i can post a couple different logs and also its having the idle issue when rolling to a stop the rpm drops and it dies
I don’t believe Lund will offer updates to ghost cam tune as it’s a novelty I believe I’ve seen them email back saying pretty much if it works it works if not they don’t spend time dialing it in.
Are you only having issues on the cam file?
I think it's normal to smell unburned fuel with no cats and a ghost cam tune. Looks like your car is about 7% false lean in the 3min idle log. What you could try is adjust the o2 sensor bias for low load/rpm where it won't try to add the extra 7% fuel it doesn't need.
Attached the Hpt file
nothing is posted
