6t40 2 gen solenoids
Hello. For many years I have been repairing automatic transmission 6t40. 1st generation known for its unreliable solenoids. And the 2nd generation has very reliable solenoids.
Sometimes I convert the automatic transmission from 1st generation to 2. Changing the TCM module with solenoids, valve body, separator plate. Also a drum inside with 3 teflon rings and some wavy discs.
For a very long time I have been interested in the question of how to make a 1st generation automatic transmission work with 2nd generation solenoids. Change PWM signal.
I think this service will be in great demand.
To clarify, you're saying if you swap the entire Gen2 valve body with the solenoids, separator plate, drum, and wavy discs into a Gen1 transmission, it works. But if you swap just the solenoids themselves it does not work?
Wanna do this too
Gen1 solenoids have different PWM frequency than gen2 as far as I know
It require somehow to change base frequency for all 6 solenoids (7th is on/off)
