1 Attachment(s)
FSO Torque Override Disable RPM???
I'm having trouble with 1st gear blowing past the 1>2 gear 5400rpm shift point JUST when the tires break loose.
All I have enabled is Trans Spark but it doesn't seem to be enough. RPMs are just rising far too fast. All other gears are just fine when traction is lost.
Its a Super Charged 5.7L 8HP70, so it seemed logical to shut off FSO which is where its at now....but I'm thinking our a next best option to slow down RPM to make the 1-2shift is to pull enough Torque is to enable FSO.
So if that all makes sense, it brings me to "FSO OVERRIDE DISABLE [ECM] 37846 - FSO Override Disable: Below this RPM, FSO override will be disabled"
What exactly is the "Override" value?
Does that mean IF FSO IS ALREADY DISABLED IN THE TUNE , will FSO OVERRIDE DISABLE only then Enable if RPM is Above 6000rpm?
