I have good updates, now I have almost figure everything out. Lat and Lon numbers in the files represent the decimal points of the coordinates. So if you take those columns, divide all the values by 1e8 and add 0, everything will work in raceRender. For example the first row of the latitude has this value 21293961, dividing it by 1e8 and add 0, the final value will be 0.21293961. If you do it for every value everything will be perfect.
Now I have one last thing to fix: lap time table. I have manually added the lap times (see screenshot below), however the first lap of the race is not shown. The time table starts the lap timer on the 2 lap only! Everything but the first lap works, how do I fix? It is not a sync problem because everything is properly in sync, just the time table does not start working till the 2nd lap
Thanks in advance
Attachment 108259
