My First Tune Attempt - 2002 Camaro Z28 LS1(6) / 4L60E
Good Morning All,
My MPVI2 will arrive today and I plan on doing a little tuning this weekend. Below are the details on the car I will be working on. I am fairly sure that the car has the original tune, but I guess the first thing is to download that and save it and then record some data to post here for people to review. My question is, what parameters should I record to give fellow tuners the best information to work from?
Thanks,
Scott
~115k original miles, swapped into a ?75 Corvette - the leakdown tests on all cylinders were good
Engine
CamMotion LS1 Stage 2 Camshaft (214/220-115+3)
Duration at .050 - 214/220
Lift with 1.7 - .553/.553
Lobe separation 115
Intake center line 112
New valve springs
Original LS6 intake
Original injectors
New knock sensors
New oil pump/pan/pickup
New timing set
Basic intake using original MAF - located partially behind the radiator so the intake air is warmer than I would prefer for now.
New IAT sensor
97-99 Corvette manifolds into 2?? dual rear exhaust
Radiator - 98-02 F-body with dual cooling fans
Upgraded to LS6 Lifter Valley Plate - I believe this may allow more air to be pulled from the valve covers into the intake
Transmission
No modifications, pulled the pan to make sure it looked ok and replaced the filter and fluid.
Original torque converter
Current Status
Original tune, only the VATS has been removed.
Starts and runs with no issues, hesitates a bit when cold when backing out of the garage
I have put maybe 50 easy miles on it shaking things down, after a while it turned on the CIL with a code that it was running lean, which is understandable with the larger cam bringing in more air, and I guess that is the first thing I should address.
