1 Attachment(s)
Another stalling coming to idle issue
Hello, im having an issue with a car when coming to stop it dies but only happens a every once in a while. A lot of times it comes down to idle just fine and no underspeed whatsoever. I have played with throttle follower, throttle cracker, rolling idle and a bunch more. I made underspeed table aggresive to see if it would keep timing up when the rpm got low, seemed to help a bit but not much. I also did open the throttle set screw a little higher to make sure it gets enough airflow. Looking at the scanner it seems that sometimes when the throttle follower has a slow rate down it comes down stable but sometimes the follower drop at fast rate and thats when it stalls. Might not have to do with that but looking at any possible cause right now. Ill attach a picture where it shows coming down to idle after accelerating various times with no problem but eventually it dies where the follower drops down fast. Thanks for your help.Attachment 111696
