6 Attachment(s)
LT4 Stand Alone Harness With OEM Start/Stop Switch and Gauge cluster
I have an LT4 engine & all the wiring out of a 2016 Corvette Z06. I am putting it into an 81 Camaro. I made my own stand alone harness out of the factory harness, and got it to operate with the factory start/stop button. The problem I am having is that to get the ignition to turn on I have to hold the button down for approx 10 seconds. The gauge cluster lights up for a couple of seconds, then goes black for about 15 to 20 seconds, then lights back up & stays on. to engage the starter motor, I have to hold the clutch switch down then press the start button. After 2 to 3 seconds The starter solenoid engages. To shut it off, & hold down the start/stop button And the ignition shuts off. To get this all to work, I have the body control module & the keyless entry module zip tied together. I also have the lower steering column cover with the key fob slot & the RFID receiver plugged into the harness. In order to operate the dash, I have the steering wheel with the touch controls on it hooked up to the harness also. My question is, can I delete all of the unused modules out of the body control module ??. I need to remove the SRS/Airbag module, ABS Module, Power seat, HVAC, Power Windows, Mirrors, Radio, etc. Will my HPTuner work on the body control module ?? or is it only for the engine ECM. I have already disabled the VATS, etc. When I hook up my scan tool, I have 67 Fault codes in the BCM. I dont know if this is the correct place to post this, if not can someone redirect me to the correct area.
Thank You
