new injectors return fuel system end egr delete no start
Alright so i have a good one to figure out for you tuners. I am trying to get my car just to idle before i take it to the tuner. i have had zero luck with the car running for the past 4 years and have been down multiple rabbit holes trying to find the recipe to making this car run. Back story i originally built the motor rods pistons cams... supporting mods to make all the power no issues. The vehicle mod list goes as follows built motor stock compression lethal performance nsr cams 4.0 whipple with mono blade throttle body jlt 148 super big air intake return fuel system 3 walbro 450 10 an feed 8 an return boost reference regulator id2000 egr delete pa performance alternator with wiring american racing 2 inch hears 3 inch catless exhaust. My car has been previously tuned i am switching tuners but wanted to get this thing the only three changes from then to now is injectors fuel system and egr delete i have tried using id and fic data just to try and get this thing running but it just cranks no start and dumps a ton of fuel out the exhaust. I also have had a few instances that cranking the car it would spray so much fuel it locks the motor. I have tried adjusting slopes and have tried pulling out fuel from the maf which from digging up some forum searching slope seems to be the only thing that changes fuel adjustments correct me if I am wrong.
Thanks in advance to all that help!
edit 2007 gt500 5.4
Quote:
Originally Posted by
mstang_man
Ok looked at your file gt500 Starter Tune 2022 mstang_man.hpt, there are a few thing i seen that may help, the Mono Data is off, I have a psuedo 148mm Maf file it may be closer to start with, also you went from returnless to return style fuel system, i didnt see any change to the fuel pump data. Was your original return fuel system? do you have your previous tune file, before you changed the fuel injectors and turned off the egr. The car was running on the original tune? or its been a long 4yrs to trying to start the car? .
ID 2000 have two different settings one for factory fuel system the other for Return style fuel system. I gave you the factory fuel system data and not for return style fuel systems. send me an email to [email protected] i will get you squared away.
