Commanded AFR vs actual - VE table?
Wideband is showing 10.4 - 10.8ish when the commanded afr is 12.75. Is this a VE table adjustment?
Commanded AFR WOT 12.7 (per log)
Desired FA Ratio WOT is 0.0809 (12.3)
Actual AFR in WB WOT is 10.4 - 10.8ish
FA+PE Ratio is in the low 12.*s afr
This seems not right and a VE table thing. I've since pulled more PE out to see how that responds but haven't ran it yet.
Wideband is in rear stock o2 location; truck is catless.
07 Dodge Ram
Inertia Spartan Plus cam: 214/222 Duration 0.566/0.556 lift 112 LSA
Inertia heads
5.38 gears
40" tires
8500 lbs +/- gross weight
Attachment 117761
Attachment 117762
AFR vid from the log.
https://youtu.be/8X6ZDM9S4wg
(some easy wot with part throttle cruise towards the end)
