Jtec PCM Need Help forcing open loop based off map settings
I can not get the pcm to enable open loop instantly using the map settings. I have my Power Enrichment Map set to below what would be considered 0 vacuum and it still doesn't switch over instantly to open loop. When setting closed loop disable via RPM, I can get it to instantly switch to open loop.
Hopefully I am just missing a setting that will make this possible .
2004 Jeep TJU. kenne bell 1.33 charger, 36lb injectors, bbk Tbody.
Thanks in advance.
