Does MPVI2+ Support Reading AEM 30-0310 thru CAN with ProLink cable?
I purchased the MPVI2+ with the ProLink cable and connected the CAN +/- directly to my AEM 30-0310 Wideband CAN +/-.
I fired up VCM Scanner, connected to vehicle, repolled for parameters, and I do not see the CAN AEM WB showing up in the parameters list (should see as another OBDII controller).
FYI... The AEM analog signal works thru the ProLink however I want to use the 2 ProLink analog wires for other inputs.
Does the MPVI2+ with ProLink support directly reading the AEM 0310 thru CAN?
Thanks!
