tips for a safe melody
CAMARO 2SS 2017 ECS SUPERCHARGER LT4 FUEL SYSTEM /JMS /DSX IAT BARO/SECONDARY CATALYSTS REMOVED/FUEL 93 /
AEM X-Series OBDII Wideband
Attachment 119327
Attachment 119328
Attachment 119327
Attachment 119328
not sure if your wideband input is reading right
i would have is around 12.3/12.5 AFR
in the penultimate acceleration kr is seen ..
for what reason can it be?
thank you
dyno data
575 hp @ 5680 at wheel
fuel 93
thank you[/QUOTE]
11.9/12 afr is good and safe
Yes... my ecs supercharger brought pulleys for 10 psi...
waiting pulleys to drop to 7 psi
575 hp is generated at 5650 rpm at 7 psi
then the curve falls...
Test in 7th gear... so as not to exceed the pressure... up to about 5500 my car registered
a speed of 189 miles from gps .. it was more for security court ..
Why doesn't it generate more hp...continuing to increase pressure?
What can I modify in my melody to take advantage of the psi?
improve fuel octane
THANK YOU
when I install the pulley for 7 psi, will it generate the same hp? at more rpm?
Will I have to change my melody?
correct airflow?
thank you
Attachment 119816Attachment 119817
log and corresponding map
kr problems .. this map was installed before acquiring the car
the required pump pressure was only 2350
maybe there could be a reason why it was configured that way
I remember that the car has a complete lt4 upgrade
secondary cat removed
faulty wideband
previous map with more pressure less kr
makes sense?
@grcam6 is right, 10 psi is too much on a stock bottom end LT1 on 93 octane gas. I would pulley to 7 psi if you’re going to run the car hard.
No since you’re lowering your boost. But you would want to check MAF scaling if you were raising boost (inadvisable in this case).
thank you!! your information is very useful
when I install my pulley I will have more news
sorry for my English
learning the language
I am from Argentina
No problem, happy to help.
Read this HP Tuners Gen V forum top to bottom…lot of great tuners with good advice here over the past few years.
