I need help explaining the mysterious misfire
I have RAM 2019 DT 5.7 with CAI, Lt headers catless, ATI dumber pulley, h pipe dual exhaust
The truck was a true dual 2.5 inches runs great
Recently I changed to a 3-inch H pipe
Currently, I'm struggling with the misfire engine only at part throttle the check engine light blinking four times. When I scan the PCM, no codes show up! Afr 15.5 to 16.7 ��It happens at part throttle
I checked the vacuum and exhaust leak?all good.
However, I disconnect the negative battery; the AFR goes normal without a misfire. Finally, the truck runs normal I think the fuel trim has been reseted
Four days later, the problem comes again where the AFR goes lean and misfires.
Where should i start looking o2 sensors?
Below video run at part throttle where the problem happen AFR goes lean and misfires
https://youtube.com/shorts/5gnh1APClfc?feature=share
At wot no misfire runs perfect !!
https://youtube.com/shorts/nOZYJrvyoDs?feature=share
