VCM Scanner Serial USB Input Channel Protocol
I have a wideband A/F gauge with only an analog output. However, it is very easy to convert that analog signal to a USB serial output (using an Arduino) that I could plug into the computer and into the VCM Scanner as a channel. However, I cannot find what the VCM Scanner Serial USB Input Channel Protocol is.
I know there are numerous A/F guages with serial outputs but they still require a serial to USB converter while my unit does not, it does direct analog to USB. I have already installed my wideband A/F gauge and wired it to my data logger. But I did not know until recently (watching an HP Academy video) that the VCM Scanner will input a channel via USB. Now I have added outputting the analog A/F ratio via USB.
I just need to know what the VCM Scanner Serial USB Input Channel Protocol is so I can format the messages/data properly. I can set up the messaging/data to mimic any existing VCM Scanner Serial USB Input Channel Protocol so no changes are required to the VCM Scanner software.
Thanks in advance.
