5 Attachment(s)
2015 STI boost control issues
Loaded the SD / Flex os onto a 2015 STI. It has injectors, big turbo, 3 port mac valve, flex, wideband logging. I have gotten over most of the learning curve and the car mostly runs ok (Have done standalones and stock gm, mopar, and ford ecus for years) but one big issue is the boost control.
From everything I have read nothing should change with the boost control strategy after switching to SD and youll actually overboost with a 3 port if you dont change any settings.
My problem is that the boost control essentially doesnt even try to feed any duty to the solenoid even with all tables stock. 1% is the highest I saw iirc. If I turn off wastegate feedback it just rides the "max dc post comp" value which is a bit wild. I tried turning all the gains off as mentioned in some other posts to make it essentially follow the base duty cycle table and I get nothing. Maybe 3%.
Im starting to suspect an issue with the OS modification but unfortunately this car was previously cobb tuned and is missing the maf so I cant try that without buying a maf. I attached tunes and logs. Crazy log shows some 5 digit psi commanded and error numbers for boost making me suspicious.
