I currently have my WB wired into one of my analog inputs, but I want to have both of my analogs available for other sensors. Can the 30-0310 be made to work on one of the CAN inputs on the Pro Link?
The 30-0310 works with pro-link like a champ. Solder CAN H and CAN L wires together and grab the correct channel in the scanner and you are ready.
Anybody else can confirm this? What is this I read on other posts about having to add a 60ohm resistor?
I have a 03-0300 wired direct to CAN H/L on the prolink. As far as I can tell the 03-0310 is the same, just no actual gauge. Wire it up and go.
exo, yes they function the same just no gauge
What is your connections?
AEMnet + to ProLink CAN High
AEMnet - to ProLink CAN Low
^^^ Wire this way? A different way?
Yea, + to High and - to Low then Re-Poll. I used the AEM WB EQ ratio 1 channel.
I'm using the exact same setup does any of the other wires get used like the ground or is that it?
I have the CANBUS model and it has an additional Analog output. Using pro it works great for the non CAN <2006ish vehicles. On later I just OBD2 port it.
