Put a tune on my buddies 2012 Ram 1500 5.7, just basic stuff nothing crazy. Now I?m getting throttle pedal position codes and the truck stalls after 30 seconds. Anybody have any ideas?
Anyone out there?
did you perform a throttle relearn?
adaptive reset
lighting bolt on dash
whats the MAP reading Key On Engine Off
Yes I did throttle pedal relearn and adaptive reset, did not do a relearn on the throttle body no. Lightning bolt on dash, and the map reading with key on engine off is 14.2 PSI
Attachment 122675
Codes that are coming up
I'm thinking the throttle pedal sensor is bad, but it worked before the tune so I'm kind of lost.
go back to stock and see what happens….
wrong data in throttle characteristic or too high values ?
I went back to stock and same thing. Customer had a pedal commander plugged inline with the pedal too. Removed that, re-read stock tune and same thing. Wondering if that pedal commander messed with the characteristics of the pedal.
Maybe I need another stock tune for a 2012 Ram 1500 5.7?
Stock tune?
Thanks F.creek
yes, stock
Here’s deal. The guy had an eBay pedal commander horsepower bullshit set in line with his gas pedal. He wanted a $300 tune including the $100 for credits. My feeling is thuss.
Please, tell your tuner if you have anything hooked up before the tune. I don’t know what hidden shit bay you have installed on your truck.
He had a pedal commander in line with the factory tpps, didn’t tell me it wasn’t installed at the time of tune
That 9-Drive box is not going to throw the codes you have shown here. If you post your current tune, I'll take a look at what you've got and see if I can figure out what's going on here and perhaps, be able to help you out...
If you happen to see this message over the next several hours, please list any and all other mods done to his Ram if you could please...
