Same for me, I have only used two sets of them but have had no issues with them.
i just put in 60lb siemans and changed ifr to match from redhardtopsupra calculator. started right up, idle good and i drove in my neighborhood 15mph or so and all seems fine. i'll drive it more next week and report back. so far no issues.
Has anyone gone through all of this for the 42lb injectors at 58psi.
I'm currently re-visiting my 'guessed' injector settings and would really like to know the correct numbers if they're available?
Everyone:
FYI, Greg Banish has the proper and correct 60# injector values for a GM. He calculated these on his own, derived from the data from Ford Racing, through a pretty intense spreadsheet he made. Yes, they are spot on, and work perfectly. If you ask him nicely enough, he may be willing to share them. No, I'm not at liberty to pass them out, so please ask him personally.
If it's right after a crank, it could be the same thing that Greg has encountered as well (Evap Purge Flow Control). It's is actually a simple fix, and it's something that Greg has asked HPT to add in for quite some time. If we had this, there wouldn't be an issue. Why HPT hasn't, who knows, but all you can do is ask again. See here:
http://www.hptuners.com/forum/showthread.php?t=10971
I tend to believe your issue is not this, however, and it is something you're running into regardless of time lapse after crank.
Regards,
James
I haven't release the converted injector data just yet because it's going to be a part of my training DVD coming out this summer. I know you guys are anxious to see this, but I want to make sure you see the info in the right context rather than just blindly copy/paste from an internet post.
Some training firms make you wait until their "advanced" material to see things like proper injector data, MAF and VE calibration in action. (If they even do it properly...) I've been teaching this stuff as part of my basic training for years because I consider it to be such an important aspect of the tuning process. I'm going to make sure it's RIGHT before I release the info and DVD.
Edit, nevermind, I figured it out
Are these still the best short pulse #'s we have?
Would someone post the latest offset #'s please
I thank all of you for the work and sharing
I'm running 60lb siemens in my set up my injector pulse widths are 2.3msec.....my flow rate vs kpa vac ranges from 69.50762 to 76.14215....my injector pulsewidth settings are 1.277......I also changed my offsets etc.....fellas my only advice on purchasing any upgraded injectors GET THE CORRECT DATA BEFORE YOU PURCHASE THEM.....Car runs like a champ with those injectors at idle (cold start) I ALWAYS RUN IT A BIT RICHER WITH ETHANOL E10 GENIUNE I MEASURE ETC and have no problem with my injector set up......14.10 at idle or 1.0 LAMBDA........It runs spot-on and pulls like a freight train.....head/cam/102mm manifold/nw102/60lb siemens ran 11.31/120.14mph before manifold/fuel st up and conv, I am chasing 10.75/124mph out of it and now have upgraded stub axles due to breakage etc.....cheers Bret
Just digested all 14 pages of this oldish thread to learn some more about the offset issues and dialing them in on an LSJ. :o There is some later info (http://www.hptuners.com/forum/showth...r-basic-how-to) that the LSJ P12 ecu offset calculation does weird things and with bigger injectors it needs 1/2 the offset values to dial in properly. Can explain why the 60's measured offset values here did not work well on the LSJ engine...
